Ir para o conteúdo principal
iMac G5 won't boot, infinite blinking LED light, and no startup sound.
I got a iMac G5 iSight 20 inch from a vintage computer store for 25 dollars, bringing it home, I put in a hard drive and new ram of 2 gigabytes, and the hard drive came with Mac OS X Leopard, I got the hard drive from the same place for 8 dollars. I powered it on and no sound, nothing on the screen, and the LED light was flashing in a loop, and you could not power it off, and the fans did not even run.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You’ll need to check the power supplies capacitors, review this Capacitor Plague. If your caps leaking or blistered time for a new supply or fixing yours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
McShyGuy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 278
