Ir para o conteúdo principal
SodaStream Source is a new way to create soda in the comfort of your own home that allows you to personalize your beverage and make only the drinks you want, avoiding all the extra bottles.
I've moved countries and the gas canisters no longer fit my SodaStream
New Zealand SodaStreams have a different thread for gas canisters. I’d rather continue using my existing machine than buy a new one. Where can I get a replacement part to allow me to use the local gas canisters?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@cmyplay Did you find a solution? I'm having the same problem.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
cmyplay try a local hardware store and see if there is an adapter for the different threads. If that is not an option, any decent machine shop could actually build one for you. Of course you could always check locally for a broken SodaStream and harvest a replacement part from that
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 358
