Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
MBPro13" shuts down during boot, recovery boot and internet recovery
Hi all, first question here :)
I’m facing very odd behaviors on my mbpro, can you help me fixing it?
Laptop: MacBook Pro 8,1 (Late 2011)
List of related (I think) issues:
  • shuts down during boot: Apple Logo, progress bar ~10%
  • shuts down during recovery boot (Cmd + R): Apple Logo, progress bar ~10%
  • shuts down after internet recovery (Cmd + Option + R): sometimes I can see the GUI sometimes not
  • charger light behaves oddly: sometimes doesn't turn on and sometimes is working well (can't get the logic)
  • after a random shutdown I can restart the Mac only resetting SMC, if I don't reset the SMC the power button is dead
What I did so far:
  • changed battery with a new one (side leds are Ok)
  • run without battery, same issues
  • run without HDD, internet recovery issue
  • SMC + PRAM reset
  • removed HDD and used a new one with internet recovery, same issues
  • run Apple Hardware Test (D) both short and extended mode, no errors in both cases
  • changed thermal paste
Booting with Cmd + V:
Question: What I can do right now?
My two cents: dying SMC controller?
Thank you all for your time :)
Esta é uma boa pergunta?
Pontuação 2
5 comentários
What is your SSD drive? Make & Model
por
I've a standard Apple HDD from Seagate, no SSD.
por
I'm thinking you have a bad SATA cable here, which can explain the OS's inability to load properly. Most of the time I see this when people have upgraded to newer SATA III (6.0 Gb/s) drives and mostly SSD's Vs HDD's.
The fact diagnostics runs without failure also points to this as well.
FYI: SMC wouldn't be the issue as that only controls the thermals and a charging. If you has a 15" model then I would have suspected the dedicated GPU as messing up. The 13" model doesn't have a dedicated GPU it uses the graphics engine within the CPU.
por
Can I try booting my HDD from an external USB drive? I'll remove my HDD from the internal bay. Have I to disconnect the sata cable too?
por
If your internal drive has a bad OS, moving it to an external case won't be as useful that having a known good drive you setup from another Mac.
The internal SATA cable can be left in place (just disconnecting the drive)
por
Adicionar um comentário
1 resposta
Solução escolhida
Review what I wrote up here: Are Unibody 13" HDD Cables are compatible between years 09-12?
It will explain the issues and the needed part and why.
Esta resposta foi útil?
Pontuação 1
6 comentários:
Thank you for your clarification, can I exclude a faulty SATA cable by booting from an external USB drive?
por
As long as the the external is a clean install.
por
Brand new external USB HDD, booted from original installation disc and same issue: random shut down. Any idea? (no HDD in the internal bay)
por
Sadly, this is boiling down to a bad logic board ;-{
It might be as simple as a bad solder joint or a worn component. You'll need to find someone locally that has deeper skills and the needed tools to fix your logic board or you could just replace it.
This is still a very desirable system! It's worth fixing.
por
Thank you for your help, @danj
(first question here, can I accept your answer for your kind help?)
por
Exibir mais 1 comentário
Adicionar a sua resposta
Kevin Borghi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,347
