Ir para o conteúdo principal
The JBL Charge 2+ made by JBL is the second generation of the JBL Charge brand.
75 Perguntas Visualizar todos
When plugged in, ON button is lit up a solid white but does not charge
Was playing music , all of the sudden it shut off ! I thought ok needs to be charged! Plugged it in and instead of the volume dots lighting up as it charges , just the ON button is a solid light and nothing happens. Won’t turn on. Won’t charge.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Let me ask you a quick question has it ever been dropped or spilled water on it or anything other than wet or did it just all of a sudden just working fine never been damaged haven't dropped it and shut off
Esta resposta foi útil?
Pontuação 0
1 comentário:
It has been dropped by my toddler so from maybe 1-2 feet in height. Was not dropped in the moment that it stopped working
por
Probably need to change battery
Pontuação 0
Adicionar a sua resposta
kmatuszy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 59
