Ir para o conteúdo principal
The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
32 Perguntas Visualizar todos
Delay in start charging ipad
Recently I bought an iPad mini 5, it works perfectly fine and keep battery very well but when I want to charge it when I plug it into the charger it sometimes take a few seconds (like 4-8 seconds) to start charging and I have to mention that I use Ipad’s original charger and cable and I also used anker power bank also my iPhone charge but I still have this problem.
Any one has experienced it? and anyone knows is it serious problem and is it may damage my iPad?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
7 respostas
Pergunta mais útil
Exact same issue here on the iPad Pro 2020: can vary between 10 seconds to over a minute! And that’s with the official USB-C charging cable and fast-charge plug that came with the device
Curiously, using an old iPhone adaptor and USB to USB-C starts charging the same device immediately
And likewise: the official cable and charger are recognised immediately if the unit is powered off
Bizarre, very basic, issue
Esta resposta foi útil?
Pontuação 1
I also have this problem, I think it’s an issue in iOS/PadOS as I’ve seen iPhones also do this is some versions of iOS.
Pontuação 0
I am currently going through this issue. I have tested on Apple branded and other brands of charging wires and ports but issue remains. I’ve contacted Apple and I got my replacement today. Issue is also on the replacement.
Pontuação 0
1 comentário:
Maybe its an issue with many ipad minis, mine does the same
por
My new ipad mini is always have this same issue :( whats wrong :( do you think this is an ios problem?
Pontuação 0
My Ipad mini 5 also has the same problem. Everything is perfectly fine but still it is anoying
Pontuação 0
Mine also does the same sometimes it takes 15 seconds, no delays when it’s powered off though
Pontuação 0
You should turn off your device before start charging..
Pontuação 0
Adicionar a sua resposta
navid arbab será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 2,197
