I replaced the motherboard for my S7 G930F with G930A
The Camera did not work is that because the code G930A not the same as the original one G930F?
Esta é uma boa pergunta?
There are three rear camera variants for the S7 and they’re not all interchangeable. You’ll have to purchase the corresponding camera that is compatible with the replacement motherboard.
Esta resposta foi útil?
I also tried tue sim card there was no Signal. I will change the motherboard and get the same motherboard with code G930F. Thank you for the advise .
Same instance with charge ports as well. There are a few variants to some of the components found in Galaxy devices. Good luck!
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 160
