Ir para o conteúdo principal
Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
468 Perguntas Visualizar todos
iPhone XR Battery Service warning with original battery.
I recently swapped my xr battery with another genuine battery, got the service warning, ok, so I put back the original battery, reboot, factory restore, hard reset and the warning will not go away! Any ideas? ios 13.3.1
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I checked, says battery may have been changed. But its the original battery.
por
Maybe a component near the battery connector got knocked off?
por
Adicionar um comentário
1 resposta
Solução escolhida
That’s strange. I would check the battery info on 3uTools under verification to see if the original battery is indeed being detected.
Let us know what is displayed.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I checked with 3utools, it says the battery may have been changed. It isn't even sure. While I am 100% sure. I guess because I plugged in another battery it tripped this warning and putting back the original battery does not reset the warning. Damned iOS 13!!!
por
Adicionar a sua resposta
Jimmy James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 337
