Ir para o conteúdo principal
The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
My S9 won't charge.
Hi,
My S9 one day suddenly stops charging with a “moisture detected” error. I never exposed it to any kind of moisture or water as far as I know. I went to a repair center, they opened it and blow it with a heat gun but still didn’t fix the issue.
So, I took it home and tried to fix it myself, I found a video on youtube which solved the problem for one day. (Basically, what the youtube video said was to turn off the phone, turn in on again and just when the samsung logo appears, plug in the charger). But after a day, the phone completely stops responding to a charger and won’t even show a moisture detected error anymore. Plugging it on a PC doesn’t work, ADB sideload doesn’t work, however download mode works though which allows me to flash a new firmware. But it still doesn’t charge even after flashing a new firmware.
So, I pretty much gave up and bought a new charging board, installed it and it again worked only for a day. I still can connect it to a PC on download mode and that’s about it.
It has been more almost half a year since this problem started, so even if there was moisture inside, I think there is enough time to dry up by now. I never even use this phone anymore because of the issue. If anyone have any idea on how to proceed on resolving this issue, please let me know. Thank you.
PS : Wireless charging works.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Since this isn't really an answer i'll post it as a comment. The healing factor seems to be time. My aunt had the same problem with her S8. She bought a new phone and used it. After about 2 weeks she asked me to get the pictures off her S8 und just for fun i tried to do so using the usb connection. It worked like a charm. It even charged using her charger, which didn't work at all before.
por
Adicionar um comentário
1 resposta
Solução escolhida
@ukim if it truly had water damage by know you’d be dealing with corrosion of components and traces on the board. i suggest you follow the troubleshooting flowchart for your phone. You already replaced the SUB PBA so now check the rest and see what you can come up with. BTW you did try a new battery as well.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
39s será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 62
Ao todo: 7,409
