Ir para o conteúdo principal
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
Help!Xbox 360 E won’t stay turned on.
After a possible overheat I took apart and cleaned it. I let it set overnight and the next day it booted up just fine and I used it for about 7 hours and then I shut off and won’t stay turned on. None of the lights indicate that it to hot.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Apart of the motherboard maybe fried - the xbox 360 E goes for so cheap it maybe better to replace it.
Did you clean the fan? It is working?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes I cleaned the fan and it is working
por
Adicionar a sua resposta
Crazycakes125 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 87
