Ir para o conteúdo principal
iPhone 6s suddenly screen blured and died
Im using my Ip6s while charging and it has 50-60% batt. Suddenly the screen blur and then turn black then die, Now my phone wont open at all no response like completely dead i try to open it by pressing power button no response, plug in to charger no response i try preasing vol up and dow plus power button and it just vibrate
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Rule out parts first by replacing the screen. They are not that expansive.
por
Adicionar um comentário
2 respostas
The battery could be dead. Leave it on charge for at least 2 hours.
Esta resposta foi útil?
Pontuação 0
Same here, two months old. Simply recharged and pressed the sensor button and whoa....blurred screen and no response. I have found a solution that has worked both times:
1) Let the phone charge for an Hour
2) Keep cable plugged into the phone, but remove it from the computer or wall plugin.
3) Hold the Home button and right-hand side button down at the same time for like 30 seconds.
4) Your battery symbol will return. (If it doesn't, plug back in and repeat steps every 10 minutes)
5) Plug the USB connector back into the computer or wall plug.
6) Leave the phone alone to 10-15 minutes while it charges enough to turn it on.
If this doesn’t work, you could take it back to Apple and ask for help.
Pontuação 0
Adicionar a sua resposta
Kiel Gons será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 162
