New Battery Bad / Dead already?
Hi everyone!
I just tried replacing the battery on my surface pro 4 and it is not turning on anymore. I suspect the new battery (Type DYNR01 / G3HTA027H) to be faulty as I measure 0V between the pos. and neg. pad on the end of the ribbon cable. However I am not sure if and what I am supposed to measure on a battery that is disconnected. Between the pos. and neg. pads are also 4 additional Pads (SMBD, SMBC, DET & INT).
Does someone know if there should be a measureable voltage between the pos. and neg. pad even when the battery is not connected? And if not, can someone give me a hint where on the motherboard I should be able to measure a voltage when the battery is connected?
That would be a tremendous help!
Thanks in advance!
Add: I did check the known resistor close to the cpu as well as the diodes that often times turn bad. But both seems to be ok. If anyone knows more parts I should check please let me know!
Esta é uma boa pergunta?
