Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Perguntas Visualizar todos
iPhone XS won’t charge after charging port replacement
Hi,
i had to replace my charging port and everything seemed to work fine after I started it. However, the phone would only stay on for a few minutes, then turn off and on. Stay on for a few minutes, etc.
Now, when I plug it in to charge, it indicates it is charging, but doesn’t appear to be.
Im wondering if the charging port assembly is bad or if something else is broken.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
An iPhone XS that boots but restarts every few minutes is most likely caused by a faulty battery or dock connector.
Esta resposta foi útil?
Pontuação 1
Try wireless charging it. Does it charge up ? If yes, at least you know that the charging IC doesnt broke.
Also, try to recheck your insttalation. Whether there is any loose connection.
The fact that your phone only stay on for few minutes is quite worrying though
Pontuação 0
Adicionar a sua resposta
Rob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 722
