Ir para o conteúdo principal
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Perguntas Visualizar todos
Leaking from under machine since I cleaned trap
When I cleaned front trap hose was not connected to plug Cleaned trap and started machine Water drained out from bottom of machine. Rechecked trap to make sure it was tight assume hose has been missing prior to today. Started machine again Water drain to floor
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Make sure both trap inlet (pump outlet) and trap outlet hoses are secured on the trap with hose clamps and also that the trap outlet hose did not pull away from the tub. I’ve done a coin trap cleanout on this type of machine and was surprised how skewed the hose clamp / hose looked on the tub side.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Roser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 218
