Ir para o conteúdo principal
Light blue and white striped vertical lines instead of just white
Hi all
My display has thin light blue and white striped vertical lines instead of just plain white.
It is not replicated on an external monitor though.
Sounds like a display or possibly a signal delivery error (cable) rather than the on board graphics processor.
After reading some of the replies to similar questions, I pressed each side of the iSight camera to no effect.
Is that a correct deduction?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, your internal display has a problem. While not visible there is a logic board within the lid which converts the LVDS signal from the main logic board to the needed raster signals the LCD its self needs.
Here’s the needed part:
A1226 Santa Rosa: Matte 661-4342 & Glossy 661-4343
A1260: 661-4609 Matte & Glossy (both used the same P/N)
And here’s the guide to put it in Substituição do conjunto do display do MacBook Pro 15" Core 2 Duo modelos A1226 e A1260
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Dan. That's very helpful. And super speedy too. :-)
por
Adicionar a sua resposta
davidjevans será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 398
