Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Used a metal to unlock display cable, sparked and Mac restarted. Dead.
I suddenly got a red vertical line in the display and then I opened the Mac, undid the display cable with a metal tool, there was a small spark ⚡️ and then my AirPods disconnected, I opened the Mac and see it has been restarted (with colorful images) and then I enter into the Mac, everything gray, normal windows where there, like logos are colorful but no desktop picture and all plus windows were Weird sized..! I restarted but it wasn’t restarting so I long press the power button.
Tried turning in, but no luck, opened, disconnected the battery and reconnected, fan works sometimes and the trackpad clicks.
when connected to the MagSafe it’s orange
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
For as much as I can sympathize for your loss it’s quite clear you don’t have the skills to fix the fault or you wouldn’t have caused it in the first place by using metal tools on a running board which is about the best one can do to cause extensive damage. Taking your Mac to a shop/lab into component level repairs would be the best you can do to get it fixed, or contact Apple if you prefer.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
StanlyYa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 67
