Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Perguntas Visualizar todos
Late 2009 MacBook won’t detect internal hdd
A while a go my old MacBooks hard drive failed I wanted to upgrade it anyway so I bought a new 120gb ssd and a new hard drive cable (because the other one had a tear in it).When I hold option on startup it doesn’t detect the disk and when I go in disk utility from the OS X install disk it dosent detect it.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like you bought the wrong type of SSD. Your system only has a SATA II (3.0 Gb/s) interface so you do need to get a drive that is able to run at this slower I/O speed. As an example the Samsung 860 EVO SSD is able to run at this I/O speed. Here’s the spec sheet for reference Samsung 860 EVO SSD Spec sheet. You’ll note the ‘Interface’ line lists SATA II as supported. Make sure the SSD you bought states it otherwise its a fixed SATA III (6.0 Gb/s) drive which is what most are these days.
You also want to install macOS 10.12.x Sierra as the best OS. While you can go up to 10.13.x High Sierra. I don’t recommend it as the newer APFS file system does not play well with SATA based drives.
Esta resposta foi útil?
Pontuação 1
4 comentários:
The ssd I bought that was pretty cheap and it only runs at 530 MB’s per second (https://www.bestbuy.com/site/sandisk-120...) so it’s definitely SATA one plus I got a new hard drive cable. I ordered a usb to SATA adapter so I could see if it’s just another bad cable or the SATA controller on the logic board unless anyone else has any other theory’s.
por
Cheap does not mean it's backward compatible.
SanDisk 120GB SSD Plus SATA III 2.5" Internal SSD (G27)
MFR #SDSSDA-120G-G27
por
Yep! A fixed speed drive SATA III (6.0 Gb/s) Won't work in this system.
por
Ok thanks I’ll order a different one
por
Adicionar a sua resposta
Spencer Brace será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 126
