Ir para o conteúdo principal
The Mi 9 is a mid-range smartphone by Xiaomi which was released in February 2019. Featuring a 6.39" super AMOLED display, a main camera with 48 MP plus an ultrawide 16MP and a 12MP telephoto lens, an under-display fingerprint reader and a 3300 mAh battery with fast wireless charging.
36 Perguntas Visualizar todos
Xiaomi Mi 9 v Mi 9 SE - build difference?
I need to replace the screen on my Mi 9 SE. Does anyone know if the build on this model is the same/similar to the standard Mi 9 model? Will this guide be relevant/useful for the Mi 9 SE..?
Xiaomi Mi 9 AMOLED & Digitizer Replacement
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The Mi 9 SE is significantly smaller than the “standard” Mi 9. The display for one won’t fit the other, however, the guide applies to both devices, as it’s basically the usual way of display replacement. Good luck with your repair!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Percy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 444
