Ir para o conteúdo principal
{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
199 Perguntas Visualizar todos
Is it possible to replace or repair power button (touchID)?
My touchID has never worked (bought the machine used) and after apple store examined the device the power button does not work at all. I looked at the teardown guide and they don’t go over this part or anything, I had hoped to open the machine up and check if it was correctly plugged into the board. Is this process feasible? And What part should I replace this with if it does turn out to be damaged?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sure you can replace it with a new logic board as they are tied together!
TheBookYard - MacBook Pro Retina 13" Mid 2018 logic boards with TouchID power button
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Matthew Saunders será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 145
