Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Data recovery from unrecognized phone
I have a iPhone 5c that i’ve broke and repaired the screen on at least 6-8 times but eventually the gold connectors on the logic board became brittle as they were not meant to be bent back and forth so many times and a piece broke off
Years later i’m still trying to recover my photos and videos from that time of my life
The whole display is visible just a couple vertical lines, touch wont reliably work but with lots of effort will cooperate.
I cant remember my iphone pin
I dont have an icloud or itune backup
PC doesn’t recognize the iPhone but detects its connected.
If i had anything but an iphone in this current functioning state you’d just plug it in and copy the photos off but not iphone, no that’d be too easy. Instead you must use itunes which wont recognize my iphone because i cant unlock it to trust my PC
A problem like this just shouldn’t exist its something apple has manufactured to blue ball you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The port is damaged or the drivers arnt installed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Austin Sidman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 49
