Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
Blue blinking light, with no video out
PS4 was recently shipped across the world (Worked perfectly beforehand).
Reconnected to same TV as before it was shipped, and the blue status light blinks with no video output being received to the TV.
  • I replaced the HDD but the same thing happens.
  • The PS4 remote is able to turn the console on when plugged in via USB.
  • Safe mode cant be activated through holding down the power button for over 7 seconds. Second beep occurs but safe mode isn’t entered.
  • To turn off the console, the power and eject buttons need to be held at the same time.
  • Multiple HDMI cables have been tested on the machine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try to replace HDMI cable if doesn't work this means ur HDMI chip which which manages the HDMI controller is short. Get it replace and it will work as nothing happened.
Esta resposta foi útil?
Pontuação 0
5 comentários:
Unfortunately this hasn't resolved the issue. The machine still remains unresponsive.
As a side-question. The computer store that I purchased the replacement HDD from mentioned that the drive requires initialising before installing. Any knowledge about this?
por
Bro u are saying it gives no output so how can u initialize a drive in safemofe when there is no output to TV. Your HDMI controller in ps4 is short usually this happens through a electric shock during storm. You should take it to a repair shop and replace that component.
por
Get ur Panasonic HDMI port replaced.
por
Hi! Are you sure that it's the HDMI port ? Usually the PS4 would turn white instead of blue with no video output. Or also called "WLOD". This could be something else.
So the harddrive is already replaced. Could you run tests on another TV? In the worst case, it could be the APU..
por
There is a circuit inside ps4 with the HDMI port the controller is Panasonic video controller and that is burned. 100 percent
por
Adicionar a sua resposta
Nick Plaskassovitis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 205
