no sound after speakers replacement, but laptop makes popping sound
hello everyone, my laptop randomly started making this horrible sound whenever i would try to play a video or listen to anything with the internal speakers. it would also make a popping sound before a video would start or when i would turn on or off the laptop.
so i bought replacement speakers and followed the instructions very well, im certain i did not mess anything up and put everything back to where it belonged, it was fairly easy. but when i turned on the laptop it still makes those popping noises on boot up and shutting down, also when im about to play a video. the good thing is that no horrible noise comes out when trying to listen to something, the bad; there is no sound in general. nothing at all.
so my question is.. what should i do?
Esta é uma boa pergunta?
3 comentários
I wish you had asked us first how to diagnose your sound issue.
What does a bluetooth speaker or headphones sound like? Lets see if the the issue is limited to the analog side.
If that bluetooth connection sounds OK unlike your internal speakers lets try a wired speaker or headphones does that also sound good?
por Dan
Darn I will remember that in the future. The MacBook doesn’t have Bluetooth , but if I connect headphones in it sounds perfectly fine
por yuderka aybar
Are you sure your bluetooth is not working? This system does have it. That maybe a clue here!
2015 Retina MacBook models
por Dan
