Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Colored lines on screen
So I'm debating buying this MacBook due to it's cheap price because of an issue. It has lines across the screen, it doesnt look like the LCD is cracked. Could it just be a loose cable on the motherboard?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
This is a problem with the lcd. Unfortunately, it looks like it needs to be replaced
Esta resposta foi útil?
Pontuação 0
@ran9aa - As the lines are equally spaced and repeat across the image this a display assembly failure.
Within the display assembly you have the LCD panel and you have some logic which converts the signal from the logic board to the needed signals the LCD needs we call this logic a T-CON board. In this model it is part of the display assembly MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly and here’s the guide to put it in MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
So depending on what the cost of the system and its specs it maybe worth it, knowing you’ll need to fix it.
Imagem de Replace a display compatible with the model A1502 late 2013 to mid 2014 Retina 13" MacBook Pro laptop. Includes the Retina 2560 x 1600 pixel 13.3" LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Produto
$449.99
Pontuação 0
Adicionar a sua resposta
Jakob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 158
