Ir para o conteúdo principal
Nissan introduced the sixth generation Sentra at the 2006 North American International Auto Show in January.
11 Perguntas Visualizar todos
Car turned off while idleing
My 08 sentra the cigarette harness has a short will it cause my. Car to just shut off
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
is it running off a separate fuse or the ignition feed, if its on its own separate fuse then not it wouldn’t turn your car off, if its wired into the ignition then it may cause issues depending on where the fault is and if it was originally wired in that way or installed afterwards.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Norberto Cisneros será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 9
Duração total: 95
