Ir para o conteúdo principal
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
468 Perguntas Visualizar todos
Gboard is not available so now I cannot sign in. How can I fix this?
I have a Lenovo Tab 10 TB-X103F and today it said Gboard not available. Now I cannot enter a password to open the screen to do anything. How do I fix this? Reboot nor power off then on fixes this problem.
Esta é uma boa pergunta?
Pontuação 9
13 comentários
I have that too but can't go on Windows
por
I am in the same situation - Lenovo tablet, keyboard not working so can't enter my password?
por
Same problem. Can't unlock tablet.
por
me to not been able to sign in since 14th dec come on google fix this problem
por
A soft reset fixed this issue for me! @Per Morten Berg
por
Exibir mais 8 comentários
Adicionar um comentário
3 respostas
Pergunta mais útil
This is a widespread problem today. Fortunately, Google has already released an update. If you can’t log in to your device, and you don’t have auto-update turned on, then go to Play store in Windows and push the update to your device.
Update (12/18/2019)
Go to https://play.google.com/store/apps/detai... on a Windows PC (log in with your Google account info if necessary), click on Install (or Installed), choose the device that is locked out, and click Install. Of course, this will only work if the device is online (WiFi or cellular).
Esta resposta foi útil?
Pontuação 2
8 comentários:
I have the same problem, but can't do anything as I cant type my password to open the device
por
how do you push the update to your device
por
same problem and have pushed update to my device nothing has changed gboard doesnt work still
por
I'm the same here. I have three devices so when I go to play store it shows two devices already updated & gives no option to push the update to the locked out device.
It is set up to auto update but very often they don't. You have to go in & push go. But as I can't get passed the password screen I can't do it. The device has been left on 48 hours & still rendered useless.
por
How do you push the update to the tablet?
por
Exibir mais 3 comentários
There should be a tiny hole (only big enough for a pin to be inserted) on the side of the device. On my Samsung it's on the top edge, on Lenovo it's on the side. Insert a pin or similar and press. This soft reset allowed my device to install the required update and returned the keyboard to working order. I then immediately removed the password.
Pontuação 0
Hi I had same problem go on to Lenovo site and it tells you how to reset worked for me I now don't sign in .hope this is helpful x
Pontuação 0
Adicionar a sua resposta
potterandy55 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 32
Duração total: 5,808
