Rear door will not open
I have a 2011 Kia Sorento, The passenger rear door will not open and or unlock. How can I fix it?.
Esta é uma boa pergunta?
when the car is locked if you stand by the door that has the issue does it make any sort of noise like the others when you unlock it, is the central locking engaging, have you tried unlocking it manually from the inside if its an option, maybe the handle on the outside is faulty and not inside if it works, ive had the outside handle fail before but inside work fine.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 31
Ao todo: 3,001
