Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
Why is phone 8 touch screen not working when home button is plugged in
iphone 8 touch screen not working when home button is plugged in. But when i remover the home buttom cable touch the screen works. the connections look clean.
I replace the screen with an original Apple screen. Even tried the original screen that the iPhone have still have same issue
I don't know if it's on motherboard issue I'm assuming it is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This is one of the common problem shown on the iPhone 8 Plus.I also faced that problem and i solved it.That problem is actually from the pin name display to MAMBA MSYNC CONNECTION pin problem.If you still stuck on that problem that is extremely helpful for you.Before doing you need some knowledge about micro soldering.Do that job carefully.
Esta resposta foi útil?
Pontuação 1
Plz help me I am stuck in this formate and how do I solve it
Pontuação 0
Adicionar a sua resposta
isaac castro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,201
