Ir para o conteúdo principal
Battery charging and draining fast
I know the 6s is pretty irrelevant at this point but I’m running into an issue. The phone seems to be charging and dying at a very fast rate. It seems to only deplete while using it though. I have rust replaced the battery and it says life is at 100% but nothing has changed. I think this may have started when I used one of those new fast iPhone chargers that come with the 11. Is this a U2 ic replacement?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If the charger you used is an aftermarket and with an aftermarket cable that might easily be the case, but unless one has a Tristar tester it’s not possible to say yes or no for sure. Tristar maybe be the reason as well as any other part that can get shorted for one or another reason, a bump or a simple inner failure. You may try disconnecting parts such as camera, dock, etc to see if you can isolate the issue.
Esta resposta foi útil?
Pontuação 1
This is a software issue because with iOS 12/13 apple slowed down older phones and even with a new battery it won’t help the iPhone the only way to fix it is to somehow downgrade the software
Pontuação 0
1 comentário:
How do you downgrade software on an iPhone ?
por
Adicionar a sua resposta
David Bertuch será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,945
