Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1187 Perguntas Visualizar todos
MacBook says its at 100% but turns off if disconnected from power
My MacBook Pro (Retina, 13-inch, Early 2015) is having problems.
I have been having this problem since last night and have tried everything to fix it or to simply find whats wrong.
The laptop itself immediately turns off when disconnected from the power adapter. The light from the adapter is always Green and never turns Orange, and the laptop itself says that the battery is at 100%.
I have tried resetting the SMC and reseting the PRAM 3+ times, which have both done nothing.
The battery itself says that it has 0 amperage, and CoconutBattery says that the battery has suffered from failure. Is there anything I can do besides replacing the battery itself?
The only abnormal thing that I did was I left the laptop overnight to charge while charging some wireless headphones through the USB port.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can you post a snapshot of CoconutBattery so we can see what it tells us Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
2 respostas
Solução escolhida
Given your systems age your battery is likely past its cycle count Determine battery cycle count for Mac notebooks
The charging logic within your system could have also failed. I often see them failing due to using fake chargers! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Lacking safety features, cheap MacBook chargers create big sparks
Do make sure you have a REAL Apple unit, don’t be penny-wise pound-foolish or be taken in by a bad charger which can harm your system as well as be a safety issue in your home/office.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Do you think replacing the battery will fix the problem or does more need to be done? The charger I have is an official one that came with the laptop itself.
por
@tobywhalele - Please post the CoconutBattery screen so I can see.
por
I have posted it.
por
Wow! You did push the count. 1,765 is just a bit over the 1,000 limit ;-}
To start with you do need to change your usage pattern to get more life from your battery (after you replace it) Lithium Ion batteries had there quirks! One of them is they don't like deep discharge/re-charge. Each time you do you loose a cycle.
You need to be more aggressive charging or just tethering to your charger when you can.
Until you replace your battery you've not going to get off your charger and you do put your system at risk as the battery often swells up! And can start a fire.
por
Okay, thank you very much for the advice.
por
It could be a defective power adapter or a bad cell in the battery itself. Also check the charging port to see if it is loose. The power port may have broken loose from the motherboard.
Pontuação 0
Adicionar a sua resposta
Toby Whale será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 107
