Ir para o conteúdo principal
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Why does my machine not drain
I have a Kenmore front load washer model # 592.4903. I put a load of sheets in to wash and the machine quit working and would not drain part way through the wash cycle. The error code came up as nd . I think it is probably plugged with dog hair but how do I clean it out?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The nd error code on your Kenmore front-load washermeans water isn't draining from the washer. The likely causes are a stopped-up washer drain or a clogged drain pump filter.
The model number you gave is for a Samsung. Anyway there are 8 possible causes that are listed here along with how to fix or parts needed:
https://www.repairclinic.com/RepairHelp/...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Wendy Adams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 2,800
