Ir para o conteúdo principal
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Perguntas Visualizar todos
LCD screen or new video card
I have an Imac 24" 3.06 2008 and not sure is the video card is failing or the LCD screen
When I turn it on, the screen is grey and it flaking black on the right hard side.
When I boot in safe mode, the picture comes up and the black flake on the right hand side
Update
nornmal boot
safe mode
Update
I had swap with the video card, same problem
Do anyone know where I can get them repaired?
Update
i had the video card fix and worked perfectly
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I connected an external hard drive and popped in snow leopard, turn it on and hold down shift.
both icon comes up and I picked the snow leopard.
the apple logo comes on and that wheel is turning.
then the screen goes, orange then pink and finial a light blue screen with horizontal lines comes
Sometime a blue clear screen comes on
I don't think there anything wrong with the video card
Could be the inverter??
I am going to check the connections on the LCD to see if there anything loose
por
Adicionar um comentário
3 respostas
Solução escolhida
Plug it into an external monitor to isolate the problem. If the external is OK, the processor (GPU) is good.
Esta resposta foi útil?
Pontuação 3
2 comentários:
hooked it up to an external monitor, same thing
por
This would indicate the video card.
por
Before I replace the video card: when I turn on imac, the apple logo comes up. Then the screen goes to orange, then pink.
Also i thinking about getting the video card fixed
Pontuação 0
got another Imac 3.06 with a failed logic board
swap the screen and got the same problem
going to swap video card to see if it work
Pontuação 0
Adicionar a sua resposta
lunchbx2 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,085
