Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Perguntas Visualizar todos
Blown capacitor on logic board. What is it?
Long story short, my logic board went out. Started smelling like burnt electronics. Pulled the board out, and found one of the capacitors on the back side of the logic board was melted.
It seems like it would be fairly easy to replace, I just don’t know what capacitor it is, or where to find one. I know it looks like a D2E Case Tantalum capacitor, but beyond that, I’m not sure.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
The Cap is one of a group: C7370 which is a 68UF 20% 16V Poly-Tantalum in a D2E case
Here’s one source: Mouser
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thanks a ton! I do have a follow-up question. (see second picture above) The blown capacitor is opposite the metal block (R36 446 RA7). I don't know exactly what that component is. Can't tell if they're connected or not.
Just wondering if there's anywhere I should check for a short or anything before replacing the capacitor?
Thanks again!
por
Also, the link seems to point to the wrong thing? It pulls up a 6.3V 220UF B case capacitor?
por
The R36 is an inductor coil Shielded Power Inductors
por
Thanks for the clarification!
por
Found this question/answer that led me to the right replacement capacitor
Cannot find Tantalum - Polymer Capacitors that match
Pontuação 0
Adicionar a sua resposta
Brad P será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 598
