Ir para o conteúdo principal
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Perguntas Visualizar todos
Screen color distortion, flickers
Hi everyone!
I’ve got a problem with my book:
Display doesn’t work fine — screen is flickering a little bit, colors are distorted. Sometimes there’s even blackscreen.
However, there is important note that it works fine only if macbook is open fully or is open at approximately 45 degrees.
Screens:
https://drive.google.com/open?id=1POYzqw...
PRAM reset didn’t help, btw.
Also I can’t change it bcs it’s 15’ and it is not a screenstage.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Sadly your display cables have become damaged! This is a similar problem we saw with the FlexGate issue which was a different ribbon cable in its case it was a bit short so it got stressed. In this case you likely banged the clutch cover just at the right place to kink the cable so over time it fatigued.
Here’s a view of the cables
You’ll need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 15" Touch Bar Late 2016 Screen Replacement
Imagem de MacBook Pro 15" Retina (Late 2016-2017) Display Assembly
Produto
$507.99
Esta resposta foi útil?
Pontuação 2
4 comentários:
Hi,
can I change the flex cables without buying a whole new display?
por
Sorry no ;-{
The cables go directly to the LCD panel you need very special equipment to bond the cables on .The lid is also glued together and so taking it apart would be close to impossible without breaking it. And lastly, were are you going to go to get the cables? They are not available either.
por
Ah, that sucks!
I read about changing the LVDS flex cable which is available for ~10€ on eBay and my hope was that this would fix my issue. Or at least I try this before investing hundres of euros.
But I guess I'll watch some display replacement videos to see if I'm capable of repairing it myself.
por
@larrygrabb - The new Touch Bar systems are the least repairable MacBook Pro's yet! Its all most a 2~3K throwaway system ;-{
I'm sure the coming Apple Silicon systems will be!
por
Adicionar a sua resposta
alexander será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 2,218
