Ir para o conteúdo principal
Informações de reparo e resolução de problemas para o RCA Voyager III, um tablet de 7 polegadas de baixo custo que utiliza o sistema operacional Android 6.0 e pode acessar a loja de aplicativos Google Play.
My battery won't charge.
My tablet was stuck in fastboot mode. Now it won't charge. When it's plugged in the battery icon with the lightning bolt shows but it doesn't move. The screen flashes on and off. Holding the power and volume buttons only makes the screen flash. It doesn't bring up recovery mode. I've tried unplugging the battery but it doesn't change anything. Can anyone help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
laurie  check your USB post as well as your charger to make sure that all of those are working okay. I’d start with a new battery since part of this can be caused by a bad battery and if nothing else it will give you a known-well starting point for further troubleshooting.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you for your response.
por
Adicionar a sua resposta
laurie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 292
