Ir para o conteúdo principal
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
50 Perguntas Visualizar todos
My tablet the screen turns on but no image just lines can you help?
Well I tried turning the screen on but it comes on but it has lines and slowly de luminates and the turns off . Can you tell me what is wrong? Is it fixable ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like the LCD is damaged. If you have taken the device apart, check that you put in everything correctly and if that’s not the case, you may need to replace the screen of the device.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks I shall try this and report back and say y/n if this has fixed it.
por
Adicionar a sua resposta
chris larkin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 48
