Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2265 Perguntas Visualizar todos
My iPhone 7 wont boot
IPhone 7 wont boot had a cracked screen//homebutton i fixt both of them except when i tried to close the screen it cracked and now it doesn't boot. Any ideas how i can fix this?
Esta é uma boa pergunta?
Pontuação 0
5 comentários:
We will need some more information. Does the screen turn on? If so what is it doing?
por
nope. i tried some stuff but it still shows no sign of life
por
Is the home button loose, can you feel a click to it? How are you powering it on?
por
For my understanding, you broke the screen again when you were closing it? If that's the case you should try with a different screen to rule out being a screen problem. Also, make sure if you unplugged the battery that you reconnected it correctly.
por
@edvinramirez56 I agree with you. Replace with a new screen and test. If the problem remains, then it might be a logic board problem. Connect the phone with DC power supply and check the boot current.
por
Adicionar um comentário
1 resposta
It is possible the screen cracking may have broken the power connection to the lcd screen.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bertil II será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 76
