Ir para o conteúdo principal
Aftermarket power adapter advice
I lost my original charger on a trip so I need to get a new one. Found a brand called Topnma making a non-branded but identical charger with same wattage and volts/amps rating. Can I trust it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
If you can wait to buy a proper charger I would hold off buying that. There's always a risk of the charger going bad and killing the laptop.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Goodman 4525
In general it should works, but it might not be properly designed like the original, e.g. short circuit protection, safety features, etc.
I know some cheap adapters, either that, output voltages can be “dirty” alot of noises, which is no good for your laptop.
cheap adapters normally efficiency and safety are always a concern.
perhaps you can save some money, but no one knows on the long run if it can harm your computer.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Goodman 4525 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 72
