Ir para o conteúdo principal
Um console de videogame para TV produzido pela Sony Computer Entertainment; o PlayStation 4 Slim (CUH-2000 Series) é o modelo sucessor do PS4 original. Data de anúncio: 7 de setembro de 2016.
569 Perguntas Visualizar todos
Do I need a new hard drive?
Ok so i think I damaged my ps4 by leaving it on for too long and it’d over heat. The issues I’m having are the ps4 shutting down when I try to load any game and getting a message saying the software is corrupted. I’ve tried many times now rebuilding the data base and even initializing it as well but still nothing. Do I need a new hard drive? Or anything else?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
do I need a new hard drive
por
@Micheal franklin Why? what are the issues? The same as the OP? Follow the answers provided.....
por
Yeah i think you do,
I think you should get a NAS drive, Those last longer and can be on for longer
https://www.amazon.com/Seagate-Laptop-2-...
Also Please check this out
tech bois
TOZO-T10
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @ramirezchris64
If there are no important data on this hard disk, you can remove it and test it on a PC.
most hard disk manufacturer provides their in house software to test HDD.
you can download and test it.
Since SSD (Solid State Drives) price are reasonable now, I would suggest you to get this instead, which I recommend for replacement, as for reliability and speed. Brands like samsung, micron should be good.
I will also get this enclosure for standby.
https://www.orico.shop/en/orico-hard-dri...
Esta resposta foi útil?
Pontuação 2
1 comentário:
The one I recommend to check hard drive health is hard disk sentinel.
If the drive reports any weak or bad sectors on the program the hard drive should be replaced.
In the rare case that it comes up with just 1 weak sector this can actually be reused without needing hard drive replacement.
por
Yes, you need a new HDD, preferably solid-state. I’m going through the exact same thing and the best thing to do is take out the bad HDD and leave it alone until you can clone it to an HDD of the same or bigger size. Chances are, the new HDD will inherit the corruption, but a database rebuild should do the trick, although you may lose some data in the process. Make sure to back up all your data beforehand, if you can.
Pontuação 0
Adicionar a sua resposta
ramirezchris64 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 20
Duração total: 2,010
