Ir para o conteúdo principal
iPhone 6s shows no service
just today my iphone 6s shows no service, this is after i notice that the battery start to swollen. Any idea what could have cause this, and how to fix it? Is it an antenna that i need to replace?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
i had a freedompop AT&T sim card, which only has data access, when i put it in it shows service. It does not get service if i put in a AT&T or Verizon sim card.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
I guess it might be the antenna, SIM slot or something severe, like damaged motherboard. Or it could be something with the SIM card itself.
Try to remove SIM card from the phone and then put it back in. Does it go from “No SIM” to “No Service”? Can you also try a different SIM card?
Esta resposta foi útil?
Pontuação 1
8 comentários:
i have tried 2 sim cards, they go from no sim -> searching -> no service.
por
Got it. You should check antenna cable then. I doubt that swollen battery would cause any motherboard issues, so that’s probably the reason behind “No Service” sign.
por
i saw on youtube there is there wifi antenna cable, thats by the speaker. Is there a antenna cable for the cellular antenna as well?
por
Yep. It’s at the left top side of the motherboard. There’s iFixit guide on how to replace it.
por
reseat the cable, still no go. does searching, then no service.
por
Exibir mais 3 comentários
If you still ahve time than show it at an Apple and Find out the cause of the problem from them. Once you know the problem, post it here. Maybe we could help you.
Actually, you have given very vague information about your problem. Getting more information about the problem you are facing will helk us to help you in a better way.
Pontuação 0
could be baseband is giving you issue this might get repair by micro soldering my best suggestion is take it to a professional with micro soldering ( iPad Rehab) and they will fix the issue
Pontuação 0
1 comentário:
what are the step to check if the baseband is the issue?
por
Adicionar a sua resposta
Charles será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 120
