Ir para o conteúdo principal
Pergunta encerrada
Keyboard backlight stopped working
My MBP is a 2.4Ghz. The keyboard just suddenly does not light up and when I press the keyboard backlight keys I get up a symbol with at light with "not available" sign over it. Seems it is telling me that there is no backlit keyboard available. I don't think I did any damage to the MBP but of course a lot of people use this machine and could have dropped or hit it. Why does the keyboard backlight stop working and how can I fix it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
You should watch all three parts of this repair, at 4:57 of Part 2 of the videos it addresses a plug that controls the backlight of the key board. if that plug was accidentally disconnected as a result of dropping it, the backlight would stop working (as it says in the video)
*Part one http://www.youtube.com/watch?v=jUonF9OSv...
*Part two http://www.youtube.com/watch?v=ty7iaWr_l...
Hope this solves it!
T.H.
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thanks for the tips. Sorry to say this did not help. I checked the cable and took it in and out. Still get the sign for no backlit keyboard connected.
por
Update!
I downloaded the app labtick from http://labtick.proculo.de/. That turns on the keyboard backlight. So the backlight works but it is not possible to trigger it when it is dark. Seems there is some sensor not working then. Do you know where is the sensor under the topcase that triggers the backlight?
por
How can I check if the sensor works? Anyone know where the sensor is exactly?
por
asle, this is what I got. "The right ambient light sensor is part of the logic board but has a removable dust cover. The left sensor is on a circuit board mounted to the left speaker."
por
Boot to a known working Operating System, does the backlight work in here? This will help diagnose if it is a software or hardware issue. There is no point trying to repair hardware when it could be the O/S. If the backlight works in the other O/S then re-install from your OSX Installation disc.
Hope this helps,
Wes
Pontuação 2
Did you reset the SMC yet?
See Apple tech note: http://support.apple.com/kb/HT3964
As one of the things it does get involved in is saving of the pref of your back light settings (display & keyboard)
Pontuação 1
2 comentários:
Yes. One of the first things I tried.
por
Did you boot up on a clean OS install off an external HD?
por
OK, so this is weird. Had no backlit keys, sometimes the F8, F9, and F10 keys acted like there was a backlit keyboard, but nothing lit up. Tried to install LabTick, but it said "no backlit keyboard." So in playing around, I pressed and held Shift-Alt-Command and then (still while holding) the power button. it toggles the keyboard backlight on and off! This is on a PowerBook G4 15-inch 1.67/1.5GHz. Hope this helps someone else. Docimastic
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 12,427
