Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
iPhone 7+ random reboots after nand reball
I recently got my iphone 7+ fixed. it had error 9 so i reballed the NAND and after doing so i put it back together after which it worked fine for a day or so.
Now it randomly shuts off and i dont know what to do, i replaced the battery, tried swapping housings nothing seemed to work. It again throws error 9 at me when i try to restore the device in itunes.
Help would be appreciated
Esta é uma boa pergunta?
Pontuação 0
1 comentário
here are the logs if anyone could take a look and help me, means alot!
LOGS:
https://hastebin.com/ulokunosay.makefile
por
Adicionar um comentário
1 resposta
Solução escolhida
Mostly on that cases that is the fault of Nand. You have to change other Nand and reprogram correct data and fix it.That issues i have faced many times and also solved by this way.
Other point by remove Nand and restore via iTunes which error shows if still error 9 that means the fault of other site.If 4014 error shows that means the fault of Nand.
Esta resposta foi útil?
Pontuação 1
1 comentário:
where are you located sir?
por
Adicionar a sua resposta
Myron. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 139
