Ir para o conteúdo principal
iPhone 7 Plus Power button not working
Hey guys!
My iPhone 7 Plus power button is not working. The button is responding, meaning it clicks when I press it and never was stuck. I used AssistiveTouch for the past couple of weeks and I would like to fix it now.
I restarted the device a couple of times and did a complete shutdown but no results.
What should I do at this point? Do a factory restore and DFu restore?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If it’s a hardware issue you’ll have to get the flex cable replaced. In the unlikely circumstance it’s a software glitch a backup and restore should fix it. Here’s the replacement guide if restore doesn’t help..since there’s no 7+ guide the one for the smaller version will be the closest you can get:
iPhone 7 Power and Volume Control Cable Replacement
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Adilet Aitaliev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 282
