Ir para o conteúdo principal
Repair and support information for HP Laptops, designed for home and home office use.
1039 Perguntas Visualizar todos
Mount screws came out, how do I get it back in?
I was following the video to replace the fan. I just got the fan and changed it but I have a new problem. When attempting to reinstall the screen, there were screws on it that couldnt come off. Only closer inspection, I saw gold (what I call mount screws) attached to the bottom of the screws. Using a few tools, I was able to separate the mount screws from the screen screws. Now… there is nothing for me to screw the screen back into the laptop.
https://ibb.co/wCkc83J
https://ibb.co/fHBDKzS
https://ibb.co/3z42c5N
https://ibb.co/mF33yy3
https://ibb.co/QM0qcV0
https://ibb.co/BPLX1py
https://ibb.co/tMqmTQs
These are pictures
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
may be use some super-glue to glue the gold to the plastic. May work or not…
Try using double-sided tape to affix the scree/cover. Or use some clear tape.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I will try the glue, If i use double sided tape, then I dont think the hinge would work anymore.
por
You could also put simple clear tape fold it into a double sided fashion.
por
I am trying the glue idea. Seems to stuck really well. Sadly, i got some of the glue inside of the screw mount, trying to remove it now.
por
Adicionar a sua resposta
dtaitt1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 282
