Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1200 Perguntas Visualizar todos
iPhoneX of Face ID question
Hi,
I’ve question about face ID on iphoneX.
The mic phone parts have;
1. proximity sensor tof & flood illuminator part.
2. Ambient light sensor part.
I tried replaced as new one of mic phone parts whole of it and I just changed original one proximity sensor tof & flood illuminator part to new one.
Not Ambient light sensor part.
Is that OK? or I have to be change Ambient light sensor part also?
Now my face ID don’t recognise my face and stuck on front camera on.
How I do now?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Im pretty sure that you can replace anything from the face ID unit event the ear speaker bit because Apple has tied it all together and the only way to get it repaired is to go to Apple at this moment in time. If someone can confirm this that would be good as I’m not 100% sure.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yeah fairly sure you lose faceID when earpiece flex assembly is replaced.
The only replaceable part there would be the earpiece speaker while retaining the same flex without losing face ID as that can be desoldered.
por
@benjamen50 Yeah I agree with that, Apple has programmed all of it so you cant change anything really. Possibly desoldering and resoldering new parts however some are paired with the motherboard like the infrared dot projector so no chance.
por
Here are some posts about face ID if anyone wants to find out more:
Why iPhone X Face ID not work after repairing
https://blog.rewatechnology.com/fix-ipho...
por
Pontuação 0
Adicionar a sua resposta
Yoon hur será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 300
