Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
iPhone X bootloop broken screen
For the first hour after i heavly broken the screen (i smashed the oled pannel underneath the glass, upon the logic board connections) the phone was fine, then it suddenly started to bootloop on the apple logo.
When connected to iTunes sometimes the boot reach the point when the phone gets identified (and gives a vibration), sometimes not
In recovery mode, trying to recover i get error 10 and 4013.
I already tried to open the phone and disconnect all the connectors except battery and lightning (no screen), but still bootloops when trying to identify using iTunes.
The phone charges (with the charging screen) and gets identified in recovery mode (and i get the connect to itunes on the broken screen), is there any way to diagnose?
Should i order a new screen or is the motherboard dead?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You should try another screen first. Error 10 is no big deal but error 4013 is. It usually means there is a communication problem between IC’s Maybe NAND, Baseband, CPU or eeproms it could be a cracked coil the list goes on and on. But a repairer would try a known good screen first on the IPhone X
Esta resposta foi útil?
Pontuação 2
2 comentários:
I just ordered a new screen, hoping is just that :) thx
por
how did you solve the problem please help I am facing error 10
por
Adicionar a sua resposta
Davide Schiavato será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 463
