Ir para o conteúdo principal
What do I need for a decent streaming PC?
Hi, so I was planning on starting streaming. My current build is a Ryzen 5 1600 with a GTX 1660 and 8gb of ram. Could I play games while streaming on this PC? Or would I be better off building a streaming PC? If I were too build a streaming PC, what parts would I need for a decent one. I am trying to make it a somewhat cheap one because I am 14 and don’t have a job yet. You don’t need to simplify things for me, I will understand what you are talking about.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you want to go cheap. since you have a decent build. I would look at an Elgato. That is rather a device for streaming then actually creating another build. You may be able to stream without problem but it is dependent on what you are trying to stream.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I will mostly be streaming Fortnite, PUBG, Warface, and Need For Speed Payback. Do you think these games will stream ok?
por
I think you'll be fine. Get something along the lines of streamlabs ans while you are playing and streaming check how well it is processing.
por
Adicionar a sua resposta
Random _User_101 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 75
