Ir para o conteúdo principal
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Perguntas Visualizar todos
Why does my 3ds turn on , blue light, then pops and turns off
A while ago I was fixing the lcd of my 3ds xl and I got done and I gave it to my brother who dropped it now when ever he turn it on it would cause the problem above so now I got back to it and replace all the top screen ribbons, lcd, camera , speaker which the actual speakers have broke off and still it’s doing that popping thing. Why?!? Can anyone help me
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Are all the cables connected? I know that when the DS Lite it’s upper screen isn’t correctly seated, it will cause the same issue as you describe. Also check the motherboard to check if nothing fell off or is damaged.
Esta resposta foi útil?
Pontuação 3
22 comentários:
How do I make sure nothing fell of or is broken
por
Are you able to open it up again ? You should take a look inside to see if all is OK.
por
Anything specific to look for because everything to me seems fine , maybe the p7 connector is broken
por
I held down the p7 connector and It still popped
por
I uploaded pictures of the motherboard
por
Exibir mais 17 comentários
Adicionar a sua resposta
Nic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 370
