Ir para o conteúdo principal
1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Perguntas Visualizar todos
vertical and horizontal lines with blue background
hi, my macbook air mid 2012 show some vertical and horizontal lines while no proper display on screen, look like this image
can some one give me some clues about my macbook problem?
thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Looks like the screen is faulty, maybe it was dropped before or some liquid drops got under the aluminium bezel whilst cleaning. You can double check it’s a screen issue by plugging an adapter to a monitor/Tv through the thunderbolt port, if the image is fine on external, the display needs to be replaced.
Esta resposta foi útil?
Pontuação 2
5 comentários:
when I plug to monitor in thunderbolt port, my monitor blank to save mode.
por
@mars erik No idea of what you mean by "blank to save mode". You should see your desktop on the external source.
por
@arbaman I mean my monitor blank not display anything, only flaoating message on screen tell that monitor is going to save mode
por
@mars erik I can't tell much about that, it doesn't seem to be related with Mac, did you use that monitor as external source before ? Do you have another device..a TV ?
por
its very confusing me, because when I plug to external monitor that no video/signal from the display.
por
Adicionar a sua resposta
mars erik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 517
