Ir para o conteúdo principal
The Gold Wireless Stereo Headset delivers amazing depth and audio clarity, elevating your gaming experience with custom audio modes created by developers exclusively for PlayStation®.
25 Perguntas Visualizar todos
PS4 Speaker loose from its socket
Hello! I have been having problems with my PS4 Gold Headset. The speaker is coming out of the socket. I have provided photos of the incident. Should I just pull out the Speaker and try to put it back in? What do I do??
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Hi!
As you can see in the 3rd picture, it’s held by plastic clips. Make sure nothing is blocking and press it straight back in. Don’t push it to hard in first, to check if it will fit fine. And be careful not to break it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
It’s too hard to push back in. If I take the whole thing out then put it in that way will that work?
por
Hi David,
Check this one out: How to remove the ear cups to change battery?
He explains how to open it, you could try to open it and close it back again. Make sure the beginning and the end matches where you need to click it in. Can't see it very good in your picture, but looks like the begin and the end of the speaker rail has other or bigger clips.
por
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 175
