Ir para o conteúdo principal
Abrangente conjunto de guias de reparo para consoles de TV fabricados pela Sony, desde o PlayStation de 1994 até o mais recente PlayStation 5.
4796 Perguntas Visualizar todos
Replace PS4 optical drive, or just the laser?
The optical drive on a PS4 I bought faulty (knowingly, with aim to fix it) doesn’t accept any discs. I have tried putting a game and a blu ray straight into the drive using the eject screw then turning on the console. As you see in the video linked -https://imgur.com/a/tyHL5Hf it makes this sound for a while. It doesn’t load up and I get a disc read error on the PS4. It also seemed to have messed around with the blu ray disk aswell when playing it on another console.
A new optical drive costs a lot, but just a new laser lens not so much. How do I know if I need the full drive replaced or if just the laser lens replaced?? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Which model of the PS4 do you have? Under the PS4 there is a black label with a barcode and model of the PS4. The model code starts with CUH-xxxx.
Andrew Paul has a number of YouTube videos explaining how to diagnose and fix this problem. From experience these can range from a lot of things.
Esta resposta foi útil?
Pontuação 4
5 comentários:
CUCH-1102A. Is there a video on his youtube in particular that could be helpful for this?
por
Thanks for that. Where on earth do I get the fuses from?
por
If the fuse is definitely bad you can just jump the two ends of the fuses together.
I know this is not recommended but they usually never go bad again for the same problem.
por
Thanks again. Is there a vid on how to do that??? Even if it's not a PS4 but something similar
por
Adicionar a sua resposta
vesh_88 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 40
Duração total: 2,260
