Ir para o conteúdo principal
Help locating a replacement voltage reference for power supply
I got a free AVOL 55” tv that wouldn’t turn on. After taking the power supply out I saw a broken piece I was able to find out to be a voltage reference. Pretty good chance it’s all I need. It’s on a LK-PL55020B power supply. It’s got two sets of identifiers. The first is TL431 and the second set is 0918. I can find a bunch of tl431s for real cheap, but I’m assuming the 0918 is identifying something specific about this type of tl431. Any idea how I can find a replacement? Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The 0918 is likely a date code or other production indicator. Any TL431 should work just fine. Make sure that you get the replacement part from a reputable dealer though.
Dan
Esta resposta foi útil?
Pontuação 2
1 comentário:
I went ahead and ordered one online actually I ordered 10. Fingers crossed
por
Adicionar a sua resposta
Joseph Stratton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 40
